- 18 May 2010
Hi,
This is a long shot so I dont expect any replies to be honest.
The DRPro4 comes with a middle 140mm fan which spins quite slowly compared to the outer 120mm fan
I know you can remove the outer 120mm fan and just use the middle, IMO this makes it look much nicer but in my testing temps went up which is contrary to I think it was Bitwit's testing on Youtube but it definitely went up for me.
The two fans have different mounting to case fans so as to utilise the fan clips
My question is, has anyone swapped out the middle 140mm fan with a Silent Wings 140mm High Speed case fan successfully and managed to use the fan clips?
Another option would be to remove the 140mm and relocate the 120mm to the middle as it has the right mounting on the fan for the clips
If you're wondering why the hell I want to do this, one reason is I think it looks loads better without the outer fan, the other is that I would prefer less fans in my system if I can get away with it and another is the outer fan covers my RAM
Thanks
Thanks
