Dark Souls 3 3440 x 1440 fix?
28 Mar 2004
Newcastle upon Tyne
Hi all,
I've tried online fixes for this including editing the .exe file, and still can't get this to work in the above resolution.
Is there anyone who had this problem? If so, can you point me in the right direction?
Thanks
Did you go with unsqueezed Dave? Sorry I forgot to reply in the other thread. Its been a while since I booted it up and Ive had updates turned off so the hex edit still worked. Ive updated now and after putting settings into US it keeps reverting back to default?
unsqueezed. just pressed a few buttons(make sure ds3.exe is not read only) and it works, the game gui is a bit off putting but I think I can get them to the edges too?
Doh! Exe/read only is the obvious step Ive been missing. Cheers dude. Using the old hex edit i think the gui was scaled but I cant remember TBH. As i said before, theres only the Blizzard games and the dawn of war titles that wont play nice. DOW games are getting on now but Blizzard think its an unfair advantage so they dont allow it
