For anyone with an even relatively recent PC!
The "You Died" spec(minimum):
OS: Windows 7 SP1 64bit, Windows 8.1 64bit Windows 10 64bit
Processor: AMD® A8 3870 3,6 Ghz or Intel® Core ™ i3 2100 3.1Ghz
Memory: 8 GB RAM
Graphics: NVIDIA® GeForce GTX 465 / ATI Radeon TM HD 6870
DirectX: Version 11
Network: Broadband Internet connection
Storage: 50 GB available space
Sound Card: DirectX 11 sound device
The "You Died, But That's a Pretty Nice PC You've Got There" spec(recommended):
Processor: AMD® FX 8150 3.6 GHz or Intel® Core™ i7 2600 3.4 GHz
Memory: 8 GB RAM
Graphics: NVIDIA® GeForce® GTX 750, ATI Radeon™ HD 7850
DirectX: Version 11
Minimum actually looks like *real* minimum requirements. And recommended basically looks like it'll probably be console quality 1080p/30fps. Meaning you'll still likely need a GTX770/780 or better to run at 1080p/60fps with best settings, but that's not surprising given it's double the frames per second as console.
Memory: 8 GB RAM
DirectX: Version 11
Memory: 8 GB RAM
DirectX: Version 11
