- 10 Apr 2006
- North West
I bought a couple of Mini 0801's a few weeks ago and I've finally got a chance to install them but wanted to check something on the electrical side of things before I go and blow up the car. I want to hardwire them into the car and tuck the wires away.
The power cable I have is a mini USB to cigarette lighter. A sticker on the cable says input DC 8-48V, output DC 5v 2A, meaning I only need 5v/2A to power the camera?
I was planning on using a piggyback fuse onto a 10A fuse for rear view mirror, can I simple cut the end of the power cable (cigarette end) and wire this into the piggyback fuse? Or will this be 12V and I need 5V for the camera?
Piggyback fuse
Or do I need a female cigarette socket that can connect the power cable to and then wire into the piggyback fuse?
Female cigarette socket
Piggyback fuse
