Dat Itunes & G510!! [Help]
16 Dec 2009
Bolton
So a few days ago I bought a new keyboard (Logitech G510) and it seems to have a very
annoying bug that only seems to apply to Itunes. So basically I added a shortcut for Itunes
to one of my programmable G-Keys and when ever I run Itunes I cant seem to close it
successfully afterwards. I press the X (Using Win 7 64bit) in the top right corner the program
is disappears then re-appears within three seconds afterwards and will do so every time. The
only way I can successfully close it is to open Task manager and end the process.
I've tried:
Re-installing Itunes
Assigning to a different G-Key
Updated to the latest Logitech Drivers
And being that this issue only happen to Itunes and when I have it set to a G-key on my keyboard
I believe it's just a issue with my keyboard drivers and the Itunes software. If I remove the shortcut
from the keyboard it opens and closes just fine. Even if I have the shortcut on my keyboard and open
Itunes via the start menu Icon it still wont close.
For the time being I can put up with the routine of ending the process through task manager although
it would be nice to be able just to close the program normally along with being able to have it on a
shortcut on my keyboard.
Anyway Thanks for reading,
-SKENG-
