DAT tape not ejecting from server?
26 Jun 2005
Any ideas on how to remove a DAT tape from the drive? Our server backs up to tape each night but has now stopped ejecting the tape so I can swap it (we have two copies) and hasn't backed up for a few nights.
Is this a sign that its time to move to external HDD type backups...?
Thanks.
if our old tape deck locked up like that a reboot of the server normally fixed it. then we could eject it.
as above though could be a thousand reasons.
The server is a Dell PowerEdge 800.
The DAT drive has the following on it "DAT72 Digital Data Storage", under Device Manager its called a Quantum DAT Tape drive.
The backup is handled by MS SBS 2003
Here the last error log:
04/04/2009 19:30
Date: 04/04/2009
Time: 19:30
User: SYSTEM
Backup Runner started.
NTMS session started successfully.
EnumerateNtmsObject(NTMS_LIBRARY) succeeded.
Will enumerate on 3 media libraries found.
GetNtmsObjectInformation(NtmsLibraryInfo) succeeded.
Found an enabled library.
InventoryNtmsLibrary(NtmsInventoryOmid) succeeded.
Identify Media completed
EnumerateNtmsObject(NTMS_PHYSICAL_MEDIA) succeeded.
Will enumerate on 0 media types found.
Unable to detect tape drive or tape media.
GetTapeMediaPoolName failed. (0x80070458)
GetBackupDestination failed. (0x80070458)
LaunchNTBackup failed. (0x80070458)
NTBackup finished the backup with errors.
For more information about failed backups, see the article on troubleshooting your backup at the following Web page: http://go.microsoft.com/fwlink/?LinkId=18414
Backup ended at 04 April 2009 19:30
Backup error finished with error code 0X80070458.
The tape is in the drive. The "Drive" light on the front of the drive is off, "Clean" and "Tape" are on. In Device Manager the device is showing as working fine.
Any ideas?
*EDIT* I've restarted the server and the problem persists.
Aha, I was too impatient with the eject button last time. I held it for about 10 sec and nothing happened. Its out now and I've put in the other tape and will try a backuop now.
