Data Analytics machine under £1,200
18 Mar 2016
Hi all,
I'm a business analyst specialising in data analytics and am looking for a new PC or potentially hackintosh build. I've got upto £1,200 to spend (but by no means do I need to go that high) on a tower which is to be used daily on Tableau (analytics software) along with photoshop. I do a little video editing (1080 raw footage) from time to time so support for this would be handy to - I don't game at all (unless you call championship manager 01/02 gaming!).
I've done a little research and I'm looking to go down the route of an i7 6700k as it looks like great bang for your buck. I'll pair this with 16gb or 32gb of RAM, 256GB SSD and 2TB HD. I have no idea when it comes to graphics - I produce audio, but this will be run from an interface and recorded elsewhere (although I may edit from this machine with headphones).
I've looked at the build below, which seems pretty good - any suggestions of other equipment I should consider? Should I look at 2nd hand Xeon processor for this type of work? I'll be overclocking the processor a little to!
Motherboard Gigabyte Z170-Gaming K3 Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Processor Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - OEM
Memory Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK16GX4M2B30
M.2 Solid State Drive **For Operating System If Selected** Not wanted
Solid State Drive 1 Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU)
Solid State Drive 2 Not wanted
Mechanical Hard Drive 1 Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
Operating System Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Case Aerocool V2X Black Edition Midi-Tower - Black
CPU Cooler Alpenföhn Brocken ECO CPU Cooler - 120 mm
Power Supply be quiet! Pure Power L8 600W '80 Plus Bronze' Power Supply - With 120mm Silent Wing Fan Built in
Graphics Card MSI GeForce GTX 950 OC 2048MB GDDR5 PCI-Express Graphics Card
You may want to consider the i7 5820k (should be around the same price as the i7 6700k, but it has 6 cores instead of 4, which you would probably benefit from :)
Thanks for the advice - I've looked at reviews and there seems little difference between the two. The 5820k seems a little stronger with non gaming tasks, whereas the 6700k seems the best all rounder - so I'll go for this.
So just an update here - I bought a machine, spec as below:
- Intel i7 6700k CPU
- 120GB & 250GB SSD drives
- 2TB SATA drive (for server backups)
- 16GB Corsair DDR4 RAM
So I'm looking to pickup a graphics card and WiFi adaptor to go plug in. The machine runs beautifully so far and I won't be pushing any games through it at this time - just running it as a pure data cruncher!
Build came in at £620, so I'm budgeting £100 for a 2nd hand graphics card and then a few £ here and there for upgrades (in the future)
