Data recovery from clicking hard drive
27 Oct 2007
Hard drive started clicking last night so am now in a bit of a predicament.
Need to get data recovered ASAP, yep I should have backed up
Can anybody recommend a company that does data recovery from broken hard drives at a decent price.
Was also considering trying to buy an identical hard drive and stripping the new one and swapping platters between the new and damaged drive.
I have access to a clean room for the above but not sure if any specialised tools are required to strip the drive.
Any advice would be much appreciated.
Froze the hard drive last night and gave it a shot after a couple of hours of freezing.
No joy whatsoever.
Might still have a go at swapping parts from a working model of the same drive.
Might be a good experiment.:D
Put it in the freezer.
Hmm, i have 2 old hard drives which this might help recover data off, is this safe to do? (ie it wont blow up lol).
One was an extrnal hd that tried to fly, the other one just got too old and stopped working (after clicking for a few weeks).
It shouldn't be a problem as I work in a semiconductor plant.
Will use the cleanroom at work if required.
Got a quote for recovery this morning for £500, laughed when they said they would throw in a hard drive for free to transfer my data to.
No joy whatsoever.
2 hours is nothing, it can take up to 12-24 hours but it could still be buggered.
Try it for at least 6 hours.
No idea why the freezer works! but had a couple I have put in overnight and they have worked just long enough to get everything I wanted off!
