Got a hard drive that a friend needs data recovered from.
I'm using a free and commonly available "BootCD" that boots into a PE - Pre-Environment and gives you a GUI to work within.
Now, I've found the documents I want to recover, and have selected them all to do so.
The next stage asks you where the destination drive for the files to be recovered to is.
It gives me a choice of "A:" , "C:" and "R:".
"A:" I have no idea what drive this is.
"C:" Upon looking into the drive itself, this appears to be the BootCD itself.
"R:" I'm assuming is some sort of "Ramdrive".
The problem being is that under a Pre Environment setup, like DOS, USB and Firewire connections are not supported.
So, how are you supposed to recover the required files and to what destination/media?. What am I meant to connect up to the PC to remove the files?.
This is really frustrating as we can see the files needed right in front of us but can not work out how to get them off the faulty hard drive to somewhere else!!!.
