Data storage server: CPU power usage?
6 Nov 2005
Ok here it is guys. Im looking to build a server for data storage and other low cpu intensive purposes.
Now the processor and other specs im really not bothered about, IE i dont need or want a massivly powerfull system. So my first concern is CPU power usage. I am looking to get either a Socket A or 754 motherboard, and to have a minimum processor speed of 1GHz.
My question is this. Out of all the processors that fit either of the sockets, which uses the least amount of power on load or idle? Im more concerned with idle power usage as the CPU will be idle most of the time.
What would the wise members of OcUK recommend?
Many thanks guys and girls,
Woody :)
EDIT: Have searched and googled and cant seem to find any conclusive stats.
What kind of budget do you have?
Perhaps look at a Pentium M solution as these are very low power and a 1.3GHz Banias core P-M should be cheap at auction
Otherwise the Via C3 and AMD Geodo chips don't use much power but they are very slow
A cheap Sempron could also be an alternative, one of the newer 90nm ones in particular
Well i can budget for up to £500 for everything. It wont need a gfx card as the mobo will have onboard video that will do for the few occassions that warrent rigging a monitor to it. VNC will suffice for the rest of the time.
Id like to stick with AMD if possible, but if people belive an intel chip to be better i shall take your advice.
I like the idea of a sempron chip. One of the Sempron 64 2600 chips go quite cheap. they any good?
I was unaware that the turion chips could be bought seperatly now? I take it they are S754?
Can anyone cofirm this? Because google is still providing little help... :(
ajgoodfellow said:
Over on XS they ran an Athlon 3000+ Winchester @ about 1GHz IIRC on only 1V without a heatsink and it was OK!
:eek: My word. Thats mental! Might think about underclocking a little then, just in the interest of power saving.
