Database file problem
11 Aug 2004
Perth, Western Australia
I'm trying to install an old database file into a CRM called Maximizer 9 but the old database file is a SLX_dat.mdf file and the CRM only seems to be able to import files such as csv, tab delimited, dbase and XML.
How do I open the SLX_dat.mdf file to enable me to save it to one of the above formats?
mdf files are usually SQL Server files. You should be able to use SQL Server express to attach the DB file (it will then create a missing transaction log file extension is ldf). After this you can use the export functionality to save it as a csv
Bingo. MDF stands for master database file, which is an MS SQL Server data base format.
Burnsy
I have never used SQL before so I'm a little lost here...
If I download SQL Server Express and open the mdf file in that i pressume that i can save it from there???
Pretty much, you need to 'attach' the database rather than open it though.
Burnsy
