Day 20 - Advent Calendar - Hazro Ultra-Sharp HZ30Wi 30" Monitor £699.99
22 Aug 2010
Day 20
For today's calender deal we have the Hazro Ultra-Sharp HZ30Wi 30" Monitor for only £699.99 inc. VAT. With 52.5% more screen area than a true 24" panel, this monitor has an uncompromisingly crisp and sharp output. Inject life into your work with piercing detail with the Hazro Ultra-Sharp HZ30Wi 30" Monitor
Hazro Ultra-Sharp HZ30Wi 30" Widescreen LCD Monitor - Black @ £699.99 inc VAT
The Hazro HZ30Wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. For the performance-driven individual, the Hazro HZ30Wi provides the ideal navigation perspective for your desktop in the home or office environment.
S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. The 30" monitor is available as the HZ30Wi or the HZ30Wi-Q. The HZ30Wi features a colour gamut of 92% NTSC which almost covers the complete AdobeRGB spectrum and encompasses the sRGB workspace entirely. When applied in colour critical applications the result is clear brilliance.
Wherever you need it most, the Hazro HZ30Wi performs with consistency and clarity to optimise your visual experience. The Hazro HZ30Wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30Wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again.
With the Hazro HZ30Wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail.
The Hazro HZ30Wi offers three times the workspace of a standard 19” monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30Wi is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency – and, in the case of businesses, an impact on their bottom line.
The built-in 4 port mains-powered USB hub allows for quick connection to peripherals such as external HDDs and keyboards etc. Each USB port will draw a maximum current of 500mA which allows for even the most power hungry USB devices to be connected without the need for external DC adapters.
Specification:-
- 30" Widescreen
- About 52.5% more screen area than a true 24" Panel with 1920x1200 resolution.
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 8ms Response Time (8ms Grey-TO-Grey)
- 300 cd/m2 Brightness
- One DVI-D Input with HDCP support
- Height adjustable stand
- Kensington security port
- VESA mounting compatible
- Integrated powered USB 2.0 hub: 4 downstream / 1 upstream ports
- Supplied with a Dual Link DVI Cable
- Warranty : 3 year return to base warranty
Only £699.99 inc VAT.
ORDER NOW
I thought £799.99 was a pretty good deal for a 30" Widescreen
£100 discount :eek:
Wish I had a spare £699.99 to spend on a monitor right now.
Although If I had got that spare for a PC upgrade I guess I could spend it more wisely, as £699.99 would make for a pretty decent performance increase.
Also if I was planning on one of these 30" I'd really want 3 (hehe) and also upgrade my PC so I could run games with ATI Eyefinity @ 7680 x 1600 OMG :D
OK I'll stop dreaming now :p
Still a very nice Festive Deal
