Days Gone restarts PC
23 Nov 2005
Kingdom Of Fife
Hi all, strange issue this after playing for a while monitor goes black and pc restarts! This is the only game that affects this, I have ran memtest successfully, ran OCCT power stress test, CPU, GPU and RAM for 6 hours passed. Real Bench also passes! Any ideas? I do have iCUE installed and have heard that can cause issues. PSU is HX850i which is a very good unit. Mobo is ASUS Dark Hero, with a 5900X, 32GB of G. Skill Trident Neo B-Die at 3600MHz, GPU is 3090 under custom loop with CPU so temps not an issue. Any ideas driving me mad!
Put your cpu back to stock see if the issue goes away CTR gives pretty suspect overclocks, best do the same on the gpu, you will be forever trying to work out if its bad overclock or hardware issue
a restart is usually cpu limited, if its gpu from experience it would freeze and hang. CPU or stability issues are generally restarts and blue screens.
As others have said, i would revert all your overclocks back to stock and try again.
