dd-wrt / tomato
20 Oct 2006
London
im looking to upgrade my existing router as i want to get some gigabit ports to improve transfer speed for my server/network.
can anyone recommend a cheap wireless router that has some gigabit ports. also able to run the mentioned firmwares
i was thinking of that. but i want to reduce the electrical clutter i have. also i was considering the amount i was going to spend on the switch, i could just invest into the router.
As has been discussed here many times, separate routers and switches for home equipment will generally be cheaper and perform better.
