DD-WRT WRT320N
Yarp, I'm running it at the moment. Latest build, working OK although the upgrade meant I had to rebuild my config from scratch.
Make sure you use the specific 320N mini build first, do not use the generic image. Else you'll brick your router!
randal, i know it seems cheeky, but would you mind e-mailing me (in trust) or just posting here some nots from when you did it, new to this whole thing and really dont want to brick the router?
Thanks
Sure, I flashed from the Linksys UI using this:
ftp://dd-wrt.com/others/eko/V24-K26/svn14853/dd-wrt.v24-14853_NEWD-2_K2.6_mini_wrt320n.bin
That's the hardware specific mini build for the 320N made by Eko, you could probably jump straight to the newer version:
ftp://dd-wrt.com/others/eko/BrainSl...dd-wrt.v24-14929_NEWD-2_K2.6_mini_wrt320n.bin
I'm running the release before, here's all his releases: ftp://dd-wrt.com/others/eko/BrainSlayer-V24-preSP2/
You'll need to look in the Broadcom K26 folder, specifically the bin for the 320n. Don't use anything else...!
You could probably get away with just doing the second, I only posted both links as that's the process I followed and it worked for me. Don't see any problem using a newer release, provided it's a 320N mini build.
Loads more than the Linksys F/W, and a lot nicer interface. Still has it's quirks, but a lot more user friendly than previous efforts.
The one bug I do have is that it doesn't show values for your portmaps - but they're there... weird. Not checked the latest build, may have fixed it.
