20 Jan 2013 at 16:38 #1 reiyushin reiyushin Soldato Joined 20 Nov 2009 Posts 5,342 Location Bangor NI So I've finally got my loop built but the pump won't start. The psu fan works so it seems to be powered up but the pump won't start It's connect to a molex, I've tried them all as well . Thoughts?
20 Jan 2013 at 16:53 #2 pgi947 pgi947 Soldato Joined 25 Jun 2011 Posts 16,800 Location Aberdeen Dead pump/loose wire I would say. Is it brand new?
20 Jan 2013 at 16:57 #3 reiyushin reiyushin Soldato OP Joined 20 Nov 2009 Posts 5,342 Location Bangor NI It's brand new, faulty pump i suspect, gutted!
20 Jan 2013 at 17:12 #4 Mayhems Mayhems Associate Joined 28 Sep 2010 Posts 1,642 have you give it a wiggle.
20 Jan 2013 at 17:29 #5 reiyushin reiyushin Soldato OP Joined 20 Nov 2009 Posts 5,342 Location Bangor NI The pump power cable? Yea
20 Jan 2013 at 18:29 #6 reiyushin reiyushin Soldato OP Joined 20 Nov 2009 Posts 5,342 Location Bangor NI It's making a faint ticking sound? Could it be on too tight?
20 Jan 2013 at 22:15 #7 reiyushin reiyushin Soldato OP Joined 20 Nov 2009 Posts 5,342 Location Bangor NI Solved, it was set to 5v on the molex....
