DDC 18w speed control
9 Apr 2007
Is it possible to turn the speed of the pump down its causing too much turbulence in my reservoir. Don't suppose i can just connect it to the lamptron fc6 using the rpm wire of the pump.
Will be giving it a try tonight, I'm running my pump externally so first job is to solder some new longer wires on and crimp the 3 pin Molex on.
