DDC pump problems
30 Sep 2011
Over the hills and.......
So, I keep getting this cpu fan error more or less every time I power on.
Once it's running it has been fine until I disconnected the pwm wire the rpm is now fluctuating 4545-4470rpm
I have pulled the pwm signal wire out of the plug, I have a Pwm fan connected to cpu opt header and that does not spin at 100% when I power on so I assumed that maybe the pump was not getting pwm juice :confused:to start turning.
Checked voltage at molex for 12v while pump not spinning,
Visually checked the pump and from what I can see though the frosted pump top the impeller is moving up and down now and then while rotating is this normal?
Anything else I can check, try or something?
Thanks in advance
Sometimes pumps takes a little bit of time to start up which can cause the motherboard to think nothings connected to it at start up
I know it takes a few seconds to start pumping but this one don't start at all.
I just cleaned the filter and now my pump has a leak.
Ok after cleaning the filter the pump has so far turned on every single time while cycling the on/off switch for filling the loop. While removing the filter I some how undid a rotary on the pump seems the rotary part is a bit stiff.
So now here's were the day turns **** I start a game of the division chosen my load out about to run out of the safe house hear a thud and a load of air being pumped round the loop, had to pull the power lead out.
The collar blew off where I joined the ridgid tube from the cpu block to soft tube from the filter. Looks like the glue has not bonded to the tube or the collar
"Monsoon hard lock for mission critical installations"
