- 29 Sep 2010
OK so I picked up a new sf600 for my compact build I've done.
Previously I had a Silverstone 450w.
My ddc pump i bought was previously working, but oddly it had been wired so that instead of a molex connector, it was wired into a 6 pin connector that went straight into the sata/perif section of the modular psu.
Installed new psu, did the same thing and nothing, pc boots fine but there is no output from the pump, I think I saw a tiny movement of the water then nothing, I assume the wiring for the two is different or the corsair unit does not allow direct power from a 6 pin device.
I am hoping I've not killed the pump.. I've ordered a molex kit to rewire the pump but any other thoughts or if I've likely killed my pump please let me know
the 2 pins in the 6 pin were on either the far right or far left so like
Wire. Blank. Blank
Wire. Blank. Blank
Found the wiring diagrams;
the 2 pins in the 6 pin were on either the far right or far left so likeWire. Blank. Blank
Wire. Blank. Blank
