I recently upgraded my computer and thought Id add a custom cpu watercooling loop. I ordered the DDC310 pump, however I later realised that its flow rate was only 200LPH which is a third of the other standard pumps.
Will this still be sufficient to cool my cpu with a slight overclock? how much of an advantage would I get from a 600LPH pump.
I also bought a 250x50mm reservoir, a duel fan 280mm rad, an ek supremacy x99 water blocck.
Pc specs - i7 5820k, asus x99-s
