DDR 1 Memory 2GB Sticks?
16 Jan 2006
Internet
Is it possible to get 1x 2GB DDR Memory PC3200 333.
i have someone who wants 4gb memory who only has 2 slots of ddr.
I cant seem to find any.
thanks
dave
I don't think it exists I am afraid.
But having 4gb in an old DDR1 system seems quite a lot, I think you'd be really limited by the CPU (I can't think of a CPU that runs on DDR1 that would take advantage of 4gb, only in rare circumstances)
I'd imagine it would also cost around £100 to £120 for it as 2 x 1gb of DDR1 is £45 to £50. For £100 you could pick up an older core 2 duo setup, as in motherboard ram and CPU?
i was thinking that was case. i have looked around but i cant find any. nevermind i will ask my friend to think about a new upgrade.
A lot Intel chipsets are limited to low density 1GB sticks, although I may be wrong. The more common and slightly cheaper high density sticks won't work on a lot of systems IIRC
Edit: Wikipedia to the rescue
High density DDR RAM will suit about 10% of PC motherboards on the market while low density will suit almost all motherboards on the PC Desktop market.
Have you looked on Ebay, isn't cheap though.
May not work though.
EDIT: d_brennen Your correct i think, long time since I used DDR1.
As others have said, it's time for a upgrade.
