Hi - Ive got an old pc which I'm adding ram to. It's a socket 939 mobo which is about to have an amd 4200+ X2 dual core cpu fitted to it.
I need to put 2gb of RAM in to this machine (completely replacing old ram as its 200mhz). Is there a big difference between CL3, 2.5 and 2 latency memory?
I dont know if it's relevant but i'll be using the machine to play warhammer online.
Dub
p.s. wuold I be better off getting 4gb - the mobo has 4 slots but i will be replacing the whole machine in about 6 months.
p.p.s. the OS is obviously xp.
p.p.p.s. can anyone recommend any particular ram? im looking for value for money.
Dub
I'm a bit confused as to what gfx card to get. I was going to try and find a cheap 8800 GT or GTX. However looking at the prices they are going for second hand on the auction site im thinking i might as well just go for the 4850 brand new from ocuk! What do you think?
