DDR Voltage
19 Dec 2003
Grimsby, UK
If your memory is set to auto in your motherboard's bios, is there a way of knowing what the voltage is set at? Does it just default it to the lowest setting if not is there a program that will let me see the ddr voltage?
Cheers,
Thanks for the info I'll check when I get home from work.
I'm guessing that if I've tweaked my ram timings to spec instead of slower auto timings, the auto DDR Voltage may increase to compensate??
When I was running Wolfenstein:ET with auto timings & auto ddr voltage or 2.6 the game worked ok, but with tweaked timings if I used 2.6 2.65 the game would crash or reboot the system, at 2.70 everything runs fine & the same with auto ddr voltage so im guessing the bios increases auto ddr voltage to 2.7 to compensate..... if that makes sense.
