- 13 Oct 2008
- Solihull
As above can anyone help me with this please?
I've got a Q6600 running at 3.2ghz on Air - Ordered a pre-overclocked system from Overclockers back in Sept 2007. I changed the ram a couple years back along with the GPU and PSU.
The RAM is Curcial BL2KIT12864AA106A (2 X 2gb kits i.e 4 x 1GB sticks). 2 of these specs - 2-1GB 240-PIN UNBUFF DIMM 128Mx64 DDR2 PC2-8500 CL5 EPP
The last couple days the computer keeps crashing in Windows 7 after booting (Lines on screen and computer becomes unresponsive). Have changed rolling back video drivers but this doesn't help.
Memtest is showing errors per Memory slot as follows although I didn't have time to let it complete all tests last night:
0: 86515090
1: 43257325
2: 0
3: 43257853
Therefore assuming I should try to boot with the stick from slot 2 so at least I can use the PC?
From my memory this is what happened last time and I had to replace the ram. I've get it setup to run at 2.2 volts etc. as per the manufacturers specs.
If I've got to change the RAM can anyone point me towards a decent kit? I know DDR2 is expensive now.
Will be upgrading at some point in the next 12 months as I know it's an old PC now but getting married next week so funds are very limited!
Don't even use it for gaming anymore.
Thanks for your help guys.
Matt
0: 86515090
1: 43257325
2: 0
3: 43257853
Matt
