DDR2 - ok to mismatch?
Yes, they should work OK together, but you'll only get the overall speed of the slowest stick of RAM.
So, if you're adding 600MHZ RAM along side 800MHZ RAM they'll all be automatically pushed down to 600MHZ
...Try 250 posts for the MM ;) And 90 days registration time.
But yeah, most RAM will work together mixed...Just it's 'better' to have the same RAM paired up. Rather than different speeds and brands.
