DDR2 Timings
25 Jul 2006
Hi,
Just pre orderd Core Duo E6600 and I want to know what memory should I go for?
I really want to know if there is a BIG difference between the DDr800 CL5 and the CL4 (GEIL ) stuff, does it justify the 80 pounds or so difference? ie do the tighter timings make much difference? or is there some better memory I should get?
Ive been a AMD user since day one and this E6600 will be my first ever intel processor (well except for the 386 i once owned many years ago!)
TIA
Intel rigs are supposed to perform better with more bandwith than tighter timings, the gain of better timings will be smaller than spending the cash on faster ram.
hello all
i,m also curious about this?
can someone please give us names, models, timings for the best ram for a conroe?
If you aren't overclocking then none of the Conroes need more than DDR2 667MHz (PC2-5300) RAM
If you are overclocking then you need RAM capable of a higher bandwidth eg PC2-6400. The higher you wish to overclock and the higher you raise your FSB, the more bandwidth you need from your RAM.
See here for more info:
http://forums.overclockers.co.uk/showthread.php?t=17592348
In general timings don't really matter for the Conroe's as far as I can tell.
And so unless you are going for some SERIOUS overclocking you don't need to spend loads of cash on RAM!!
The first 2 options in the gskill range seem to be highly recommended on these forums
http://www.overclockers.co.uk/acatalog/GSkill_Memory.html
whats peoples opinions about the OCZ 2GB (2 x 1GB) PC2-7200 Dual Channel EPP XTC Series DDR2 ?
good/bad/overpriced/wellpriced? ill probably be overclocking but ive never really been one to squeeze every ounce of juice out of my machine, would it probably be overkill or a good buy for general head room incase i push it further then i would push 6400?
dont really know a thing about DDR2, all these new speeds are very new to me :p
/threadhijackend :D
EDIT: alternatively im tempted by the Gskill ZX 6400 but mainly because i know gskills customer service on returns is second to none
The G.Skill HZ 6400 is the kit to get, the chips scale to DDR1000 and beyond.
Devious said:
Ram doesnt seem to make much difference on c2d systems.
http://www.firingsquad.com/hardware/core_2_memory_tuning/
Save your money and get a beter video card. :)
I already have a 7950 so how can i get a better one than that???? ;)
So what everone is saying is get the CL5 suff and dont bother with the cl4 ram. I would like to overclock a bit but nothing mad as the Conroe E6600 SPANKS the athlon FX62 in everything (Games video decoding etc). Come on Overclockers send me my chip!! I have to wait until August now (the order doesnt say when though!!! :( )
I had some corsair value select in my Athlon system. I upgraded this to some Corsair TWINX Pro ram which I did notice a difference between the two types.
PS thanks for the very informative replys guys!
That is a pretty comprehensive review, I have just read it all and there seems to be a small difference, the CL3 800 stuff is about 1-4% slowerl compared to the CL5 800 or ever the DDR2 1066 RAM which costs more (for 2 gigs)than my 7950GTX2!!!
Also what is surprising is that there is hardly any difference between the DDR2 667 and 800 stuff, so Im going to get some of that stuff I think as it is cheaper and I can get some CL3 in that it seems to be a big waste of money IMHO to get the DDR2 800 or 1066.
The way thats writing is leading me to think that there isn't a ram:fsb multi, please tell me I completely miss interpreted this post :)
Most boards have a memory divider (except for the gigabyte boards it seems) so you could run your mem at a lower speed whilst having 400+ FSB :)
