DDR2 VS DDR 3 Difference
  • Thread starter Thread starter B&W
  • Start date Start date
B&W
B&W
3 Oct 2003
Birmingham
Hi Guys
quick question, im using my Computer for gaming only
would there be a difference between 4GB DDR2 and 4GB DDR3 memory in gaming with a Q660.
regards
B&W
Very little but if the choice is buying both new, get DDR3
not really a big choice because if i want DDR3 its 125 pound for a new motherboard, but if i wanto to keep the ddr2 ram i can get the Gigabyte GA-G31M-ES2L for 35 pounds and keep my RAM.
good choice?
If you intend to keep your Q6600 then the only benefit is you coould aim for higher bus speeds.. but we are talking extreme speeds. DDR3 effectively has a better throughput so youl could run the RAM at a higher frequency but this won't improve performance by much.
I ran both DDR2 and DDR3 on my old P5KC motherboard and benchmarks should little or no difference. However, i always suspected a flaky controller on this board so who knows. Bottom line.. stickto what you have for the moment and upgrade the whole lot when you can.
ye i really want to keep my Q660, just want to overclock it to 3.0 + ghz with the Gigabyte GA-G31M-ES2L
http://www.overclockers.co.uk/showproduct.php?prodid=MB-221-GI
only thing is, when is the DDR2 4GB RAM going to go down in price, its expensive, even more so than the DDR3, which is stupid.
yonly thing is, when is the DDR2 4GB RAM going to go down in price, its expensive, even more so than the DDR3, which is stupid.
It won't go down in price anymore. Rather it'll just keep going up, since they're not being made anymore. Hence in the future DDR2 RAM will become quite valuable. I would recommend stick with DDR2 unless you plan a full CPU/MB upgrade.
Perhaps hold out for a few more months before upgrading the CPU, mobo and memory? Seems a shame to be buying more DDR2 when if you come to upgrading you'll have to get rid for DDR3.
Do you know the frequency? Run CPU-Z / memory tab to find out if you don't know.
dram frequency : 266.1 mhz
FSB: DRAM 1.1
im going to be upgrading this ram soon anyway but what does this mean and is it a decent pair of ram?
FSB: DRAM 1.1
DDR2 PC2 - 4200 I think, runs at 533MHz (2 x 266.7) fairly boggo standard.
