DDR3-1066 CL7 or DDR3-1333 High Speed
29 Oct 2006
I'm upgrading my system and need help choosing ram.
It'll be for running 3DS Max, Photoshop, Video Editing and the other usual MS Office, internet, playing music etc.
I've opted for a i7 940 proc, with a Noctua NH-U12P heatsink all put onto a Supermicro X6SAX mobo.
I'm not intending to overclock this machine, but I am confused about the memory that will be best suited for it and my applications.
I'm going to be putting in 12gb of ram.
Crucial do a 6gb memory kit which is non-ecc, ddr3-1066, 1.5v and sells around £80.
They also do a 6gb highspeed ram kit, non-ecc ddr3-1333, 1.65v and sells for £180.
So for an extra £200 I can have the highspeed ram - but what will it give me ?
According to what I have read, the i7 940 processor supports non-ecc ddr3-1066, so what would the point be of getting the highspeed stuff if I'm not going to overclock ??
If I didn't overclock and put the faster ram in, would I notice any difference (the mobo supports upto ddr-1333, the processor doesn't).
Please advise, I'm not an expert in all of this, though I have no problem building systems/installing OS's etc.
Many thanks,
Jez.
i would go for the cheaper option to match your processor speed, the difference you will see is negligable between the speed, obviously you will need a 64 OS to use the ram.
Thanks KingZeddy,
That's what I decided to do end the end - I got the Crucial Ram (12gb) of PC3-8500 for £135 in the end (D A B S was even cheaper than Crucial on this one!)
12gb of ram for £135.........
XP Pro 64bit here I come !
Jez
