8 Sep 2011 at 14:59 #1 speedyj speedyj Associate Joined 19 Mar 2006 Posts 633 Location Suffolk I have a set of 12GB Kingston HyperX (3x4) DDR3 12800 Would 2 of these run OK in a Sandybridge mobo and could I just add a 4th 4GB stick later to give 16GB?
8 Sep 2011 at 15:02 #2 Orcvader Orcvader Soldato Joined 11 Oct 2009 Posts 16,921 Location Greater London Running two of them in dual channel will run fine no problems. Assuming the speeds, timings and voltages are the same, then the forth stick should be fine running with the rest of the system.
