DDR3 mobo choice?
18 Oct 2002
UK
Just bought a E6850, looking for a mobo that will take ddr2 & ddr3 1333mhz, thats good for overclocking, with at least 6 sata conections, onboard hd audio & able to take the new 45nm cpu's for future cpu upgrade, can anyone recomend a mobo that is not gonna be to expensive that has all this?
reading all the mobo specs is startin to do my head in lol.......:D
Hmmm dual ram motherboards tend not to come cheap so your going to pay a premium unless you decide which way you want to go with regards to memory and get a single memory type board. Of the dual memory types I'd favour http://www.overclockers.co.uk/showp...Socket 775) PCI-Express DDR2/DDR3 Motherboard (as I'm a bit of an Asus fanboi) or slightly cheaper is the gigabyte http://www.overclockers.co.uk/showp...cket 775) PCI-Express DDR2 & DDR3 Motherboard both are p45 chipsets I believe so should have some life left in them as far as cpu upgrades go (unless intel ditch socket 775 ofcourse)
All of them will do a 45nm Core 2 Quad/Duo.
Personally DDR3 is an improvement on DDR2 obviously but I don't think its feasible when in less than 6 months the prices will fall (they surely have to what do people think).
You can get DDR2-8500 chips and overclock and get comparable performance to the low-end DDR3. If you've got the money definitely DDR2, if you haven't get some top notch DDR2 for far less money.
Of course it depends on your processor, if your thinking of eventually upgrading to a Core 2 Extreme, get a board that supports DDR3 spend your money and wait for the Core 2 Extremes to drop.
