DDR3 Sockets
25 Sep 2010
Already posted this one in Motherboard section so apologies for duplication.
Am I ok to install 3 off 2GB DDR3 modules into any of the 6 available on my Gigabyte GA-X58A-UD3R?
It's just that there are 3 white sockets and 3 blue.
Thx in advance.
doesn't matter which colour you fill up first.
use either all blue or all white, otherwise the triple channel performance is not used.
there you go then, but what happen when you want too add more ram? you then fill the blue ones.
