Hi guys,
Just looking for an advice since my GFX needs to be RMAed I can spend some time with this. Bought DDR4 3000mhz but noticed in bios it runs as 2144 mhz. I looked for the XMP profiling in bios and enabled it which changed the settings to 3000mgz however the system did not even boot up and I got an error ''no ram installed''. I am not very familiar with this but I am guessing that I need set the ram somehow after the XMP is enabled? Any advice would be great to get the ram going since I invested in it. I am running skylake btw so it should benefit a bit.
Thx,
Tom
Thx,
Tom
this was x99 but still with having a look if the ram volts are behaving
