DDR4 i7 6700 and ASUS z170m-plus
1 Jun 2016
Cambridge
Hi
Components are:
CPU: i7 6700 (non k)
RAM: Corsair 16GB White Vengeance LPX DDR4 3000MHz
Motherboard: ASUS Z170M-PLUS
Is it possible to overclock the RAM with this configuration?
Thanks
Yes, you can overclock the RAM on that board, you just can't overclock the CPU as it's a non-K. To be honest though, the 3000MHz XMP profile should just run out of the box and be stable without you having to fiddle around setting the timings manually.
I tired using the XMP profile and the system failed to boot. I am away from my pc until Monday. When I return I'll pay around with the settings a bit more and post my results.
