DDR4 ram for noctua nh-d15 cooler
30 Jun 2014
S-O-T
Ive been looking at the team group vulcan and the team group dark pro ddr4 memory but will either of these be compatible to fit under the Noctua nh-d15 cooler
Well the vulcan is about as low as you'll get unless you remove the heat spreader.
It's only about 3mm higher than the PCB if my memory serves me correctly (haha accidental pun!).
Although look here you can move the front fan up a bit if your case allows, for more clearance
http://www.xtremesystems.org/forums/showthread.php?293357-Noctua-NH-D15-SE-AM4
I have the DH15 and the TeamGroup 8Pack Dark pro and it fits fine. I think I had to raise the fan up a smidge just to make sure there was a gap but it's not rizzla tight.
