DDR5 MEMORY for Z890 MPG edge and Intel core ultra 7 265K
7 Jan 2010
Up NORTH
Hi all
Can anyone recommend what's the best DDR5 for the above setup, I'm not sure about CL etc for overcclocking and do usually go for Corsair if possible.
Intel ark says that 6400 is the max stock speed, but it has been reported they can hit very high speeds (8000+).
I would suggest waiting until we get memory scaling articles, unless you know someone who is playing with one already.
I think with the current 15th Gen Intel issues the higher clock speeds is best, I will now need to wait as Corsair is delivering new DDR5 in November
Hi all currently got below DDR5 ref 32GB (2x16GB) Corsair DDR5 DOMINATOR Titanium RGB White, PC5-48000 (6000), Non-ECC Unbuffered, CAS 30, XMP
CMP32GX5M2B6000C30W
Shoull I return it and wait for faster clock speeds or just keep it and tweak it as required?
CMP32GX5M2B6000C30W
Not too sure right now, have you seen this?
If it was me, I wouldn't care and I'd just keep it, but since you got a new high-end (ish) CPU and motherboard, I assume you care about getting max performance.
I know there is early performance issues but I think there will be future fixes/patches to help boost the cpu,to be honest I'm not a massive overclocker but do like to tinker lol
