DDR5 RAM - DRAM Status 4800Mhz? Corsair Dominator 2x16GB 6000MT/s C30 + ASUS X670E-Plus WIFI.
4 Nov 2022
El Mundo
Hello..
I was wondering if anyone here is able to help? I'm a bit lost with the following..
I don't understand why my system is telling me that my DRAM status is 4800Mhz when in the bios is says it's set to 6000Mhz?
Thank you in advance!
Could be a glitch
Download cpuz and check memory to confirm your at 6000mhz and same timmings as xmp.
Remember it's double date ram so it will show 3000 and then doubled .
Could be a glitch
Thanks bud..
Does this look ok then?
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR5
Module format UDIMM
Module Manufacturer(ID) Corsair (7F7F9E0000000000000000000000)
SDRAM Manufacturer (ID) SK Hynix (AD00000000000000000000000000)
Size 16384 MBytes
Max bandwidth DDR5-4800 (2400 MHz)
Channels 2
Part number CMT32GX5M2B6000Z30
Manufacturing date Week 48/Year 22
Nominal Voltage 1.10 Volts
EPP no
XMP no
AMP no
EXPO yes, rev. 1.0
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 22.0-23-23-43-65 @ 1333 MHz
JEDEC #2 28.0-28-28-54-82 @ 1666 MHz
JEDEC #3 30.0-30-30-58-88 @ 1800 MHz
JEDEC #4 32.0-33-33-62-95 @ 1933 MHz
JEDEC #5 36.0-37-37-70-106 @ 2166 MHz
JEDEC #6 40.0-40-40-77-117 @ 2400 MHz
JEDEC #7 42.0-40-40-77-117 @ 2400 MHz
EXPO profile
VDD Voltage 1.400 Volts
VDDQ Voltage 1.400 Volts
VPP Voltage 1.800 Volts
Min Cycle time 0.333 ns (3000 MHz)
Max CL 30.0
Min tRP 11.99 ns
Min tRCD 11.99 ns
Min tRAS 25.31 ns
Min tRFC 0.29 ns
EXPO timings table CL-tRCD-tRP-tRAS-tRC @ frequency
EXPO #1 30.0-36-36-76-112 @ 3000 MHz
DIMM # 2
SMBus address 0x53
Memory type DDR5
Module format UDIMM
Size 16384 MBytes
Channels 2
EPP no
XMP no
AMP no
EXPO yes, rev. 1.0
EXPO profile
Max CL 30.0
Min tRP 11.99 ns
Min tRCD 11.99 ns
Min tRAS 25.31 ns
Min tRFC 0.29 ns
the memory in the bios will always show its default speed and timmings, speed is always 4800mhz but timmings differ between kits, as long as you enable expo your ram will run at its rated max speed and not 4800hmz, its the same on my asus board, until i boot my system shows ram at 4800mhz, think of it as a fail safe if expo goes wrong the board will default back during memory traning (code15) and allow you to boot instead of not and boot looping.
all's sorted above so dont worry :)
Thanks bud anyway for the reply! Much appreciated.
