DDR5 Zen5 pre-purchase
24 Aug 2004
Glasgow
I'm looking to grab some sticks now, but I don't know what I should be looking for seeing as I'm on AM4.
I'll be upgrading board & cpu and when the X3D zen5 parts are available, whatever the 16c part is (8950X3D)?
I'm looking for highest capacity 6000Mhz+ rated sticks, what are my options?
Edit: a bit of digging reveals some success with 5200 high capacity kits on 7950, what's the perf difference on AM5 going from 5200 - 6000?
I'd honestly wait as by the time the X3D parts arrive, Likely 5-6 months after the initial non X3D parts, We'll have even higher speeds and tighter timings than we currently have for really decent prices.
I wouldn't buy now unless you're really desperate. The high capacity kits (e.g. 96GB, 192GB and 256GB) are still really immature and the volts/timings should drop over time, while the frequencies go up.
For the X3Ds, not much at all. For the non-X3D, it depends on what you're doing.
You might find these of interest (first is for gaming, includes a 7700X and 7950X3D and second is for productivity, with a 7950X).
Thanks, very helpful. I'll sit tight for now
