De fraggler caused X2 computer issues
3 Feb 2006
not sure
Hi all this is a weird one.
I used defraggler the other day to do a quick defrag of me lappy HD now every so often it will stutter games,youtube etc etc.
Any ways me main PC I thought I will de frag that to as I am trying to get ARMA2 to run smooth (wont ever happen :P) so I did a qiuck defrag of that to and guess what it now all so stutters like crap in game.
It has to be defraggler as the two started straight after a defrag with this software.
I know some of you swear by defraggler but I am all most 100% sure it was defraggler because its happened on two different computers after a defrag.
If any one would like to mess there pc up get defraggler and do a quick defrag then it will show a list of files that are defraged select all of them then choose defrag files and let me know what happens.
Thanks
Why did you use a defraggler? Was your computer filled with these?
It's not the fraggles that cause the problem, you probably should have de-doozered it first. These guys can cause havoc if they're let run free in a hard drive :
Did anyone else feel that there was something almost Nietzschean (and borderline fascist) about the relationship between the Fraggles and Doozers?
