Just De lidded my intel 3770k and lapped the shim.
used cool labortory pro liquid metal on cpu die and shim.
idle temps in windows running 4.7ghz 1.32 volts idle is 21 under load 56c using prime 95. using custom watercooling with a 295x2 in same loop. all i can say is wow what a difference its made.
if you after much lower temps give it a go. i did use the vice trick taken 3 mins to delid.
Then again I'm much more conservative with any overclocking. For me 4.5Ghz with a very modest voltage increase ensures stability and the CPU is still well within its maximum temp before throttling. I only have a Arctic Freezer Pro rev 2 cooler as well - anything else is just too humongous imo.
