Hey... so I've been building PCs since the Windows 98 days, although the most recent build I did from scratch was a 2nd gen i5 and my last "enthusiast" build was in a Lian Li V1000 and had a 6800GT to play HL2. So.. yeah... been out of this game for some time!
Anyway, I recently picked up a second hand PC mainly to run X-Plane. Seems to be a pretty decent, if not bang up to date spec - Ryzen 7 3700x, Gigabyte Aorus motherboard, Gigabyte 3070 8GB GPU, 16GB Corsair RAM. Does what I need to do just fine but at the risk of sounding like an old man - when did PCs start looking so tacky? Its in a reasonable quality case (A Lian Li Lancool 2 mesh) with a pair of RGB fans in the front, one exhaust and an NZXT AIO. It's probably one of the subtler looking PCs but it still looks like a fairground when you turn it on. I'd have loved this stuff a few decades ago, but now I'm a bit older I care more about it looking nice in the room and being quiet. And yes I could just turn off all the RGB, although anecdotally it seems a bit of a PITA to get it to do what I want and actually stay that way. The fans in there aren't terribly quiet too so worth swapping those anyway.
So is there a good benchmark for quality/classiness over blingy RGB stuff? Most of the brands and stuff I was familiar with have changed/vanished and new ones appeared. My thinking at the moment is
- Swap the RAM for a 32Gb kit without any lighting. The RAM seems to be the most belligerent when trying to tell it to tone itself down, I wouldn't mind going to 32Gb anyway and I can always sell the knight rider RAM to a teenager
- Change the case for a Fractal Design North (black/mesh)
- Change the fans to RGB-less Noctua ones
Would I be onto a decent path with that? It would leave the AIO, motherboard and GPU lighting but those are quite dim and not too intrusive, with the mesh case it should be fairly toned down?
Are there other "classy" cases worth looking at? The Asus ProArt ones look nice but pretty pricey for what they are
Posted in general as its a bit broader than just the case but mods feel free to move to the case section if you prefer!
