- 24 Feb 2009
- Teesside
I bought a BFG 8800GTS second hand a few weeks ago but couldnt test it as my PSU was a useless old unbranded one without a 6pin pci-e cable.
Anyway, finally bought a Coolermaster Real Power 520W the other day and it arrived this morning. Put everything in my case and pressed the power button... a few LEDs on my motherboard lit up for less than a second then powered down and nothing more. Tried powering up again but nothing happened at all, no LED's lighting or anything.
However, if I turn off the PSU for a minute or two, then press the power button it does the same, lights the LED's momentarily then powers down and nothing else happens.
The power supply is fine, its brand new and used the old paperclip between the green and black wires to make it power on, my watercooling pump works and fans spin so Im guessing it must be down to the graphics card.
Anyway, anybody else had this before? If it is my graphics card, would I be able to send it back to BFG as in theyre warranty is says they'll cover it "for as long as the original purchaser owns the product". Im guessing this card was introduced before 2/21/08 though, which means it did not need to be registered? If so would they have any way of knowing Im not the original purchaser?
Any help will be greatly appreciated.
Thanks
Thanks
