Dead case modded 360
4 Aug 2006
Stevenage , Wisbech
One of the guys at work asked to repair his 360 for him, its under 3 years old but has a modded case on it. Will MS still repair this for him FOC or will i have to resort to the Clamp and screw fix. Is it worth getting a repair kit off the bay or is just as easy to get the parts yourself? Also i have seen them mention a case tool is this required or can i use flat blade or something?
He will have broken the 'warranty void if removed' sticker in order to switch the case, so a MS repair is out of the question. Unsure about the rest mate but i'm sure someone will fill you in.
Well i bought me a Xclamp kit from the bay for under £3 followed the instructions, and it worked first time. No need for oven baking or even the overheat method by disconnecting the fans, is this pretty normal?
