- 6 Sep 2005
Hey guys,
Does anyone know what could be causing my laptop to be fuggered?
Basically, it was working fine one day, then I get a white screen and it becomes unresponsive. I power down and go to restart but nothing. no power light even when power supply is plugged in, no response from power button.
After a couple of days of messing around trying to see if it was just throwing a fit, I found that for some wierd reason, when I press the 'End' button on the keyboard (just so happens to be the closest button to the power button, although dont think thats relevant tbh since theyre not connected in any way afaik) the fans will kick in, the power LED will come on, but its a red/orange colour, no other signs of life, then it stops again. Does this with battery in or out, but only when the mains is connected.
Does anyone have any idea what is causing this, and is it something I can fix myself?
Cheers in advance
Cheers in advance
