Hi,
I'm looking for opinions on the probable cause of the display issues I'm experiencing, shown in the screenies below. I was using the computer this morning with no issues, went to work, and have found it behaving this way since returning home
The GFX card is an old soft-modded ATI AIW 9800SE, the monitor is an even older Iiyama VMPro 450 which for the past two months has been exhibiting (for want of a better description) a periodic screen burst - like it's firing an electron at you and it pops (inaudibly) behind the glass. It does this a couple of times per week with medium usage.
I have tried declocking the card, disabling the soft-mod and returning my CPU to default clock with no improvement.
I get the feeling the screenies do not do the problem justice; it's a ***** trying to work on here at the moment. I practically have a green mesh over everything which acts to defocus the entire display.
Unfortunately my chosen solution to purchase a pre-built OcUK O/C rig cannot be funded so I would like to replace the faulty component only.
Advice appreciated.
Advice appreciated.
