Dead Graphics card?
12 Aug 2006
I've got a Sapphire ATI Radeon X1950 XT card in my current system that I think has had its day, quicker than I'd expected as it's not that old really.
It idles at a temp of around 88 degrees but once i try to start gaming it goes up to 110 degrees almost instantly (at stock clocks and 100% fan speed) triggering ATI to turn down the clocks and make the computer beep annoyingly.
Nothing else in my system has changed recently and nil else is overheating. I've removed all dust and the stock fan on the graphics card appears to be working and has minmal dust. ATI tool says the GPU temp is 88 idle and the GPU environment (whatever that means?) is 62.
Is my card screwed? Do I need to buy a new one?
try removing the cards cooler and reapplying the thermalpaste, they usually put too much on so doesnt help too well with temps.
Might be worth a try. However considering it has been running fine for two years and suddenly decided to start playing up now despite me not changing anything I figured it was knackered.
