So only when playing path of exile I got this graphics problem (was running fine for 80 hours) and it would result in the gcard not sending a signal to the monitors. Now when i turn my pc on the screen has horizontal noise lines across it and its stuck at a low res. Windows hardware manager gives the error 43 on the gcard.
http://imgur.com/Z11A0dz,DrfJNpP#0
http://imgur.com/Z11A0dz,DrfJNpP#1
GTX 570 about 2 years old, 850Watt power supply about 1 year old.
Is it the graphics card? Did the mobo cause it? Anything I can do?
I've had GPU's artifact before due to the TIM basically being useless.
