Hi guys having some nightmares with a new MSI build, unfortunately I leave for 6months of travels on wednesday night!!
mobo-msi b75a-g43
cpu-i3
ram-8gb (2x4gb) corsair vengeance - CMZ8GX3M2A1600C9
hdds-120gb OCZ SSD
no gpu
windows 7 64bit, not currently installed
Basically, PC was stuck in a re-boot loop... played around with ram and system posts ok with both DIMM slots 1 and 2 populated, or a single stick populated either 1 or 2... loops when anything (even a single stick) is populating the 3rd or 4th slots.
Also, one odd thing, is im not able to set the ram speed over 1333mhz... ever.
product info states "4 DIMM support for DDR3 1066 / 1333 / 1600 / 1866 / 2133 / 2400 / 2677 up to 32GB Max"
So im not able to run dual channel... Will this even matter in an ofice PC? I'm sooo rushed for time!
MSI says to use 2nd and 4th slots (black) for best compatibilty...
Have checked on the MSI site compatibility of Corsair 4gb sticks... Unlike Asus' site though it does not show if tested in dual channel, just says "OK"
http://www.msi.com/file/test_report/TR10_2543.pdf
So my question is, am I to assume the slots are dodgy?
If so, i have no time to wait for RMA (I must buy another one for Next day del?), if I install w7 now, when I plug into the replacement mobo on tuesday, will windows install still be a happy bunny (i can install windows 7 with slots 1&2 populated)?
Any OCUK will refund me ASAP right? ARG ARG ARG ARG
thanks in advance for your help!!
mobo-msi b75a-g43
cpu-i3
hdds-120gb OCZ SSD
no gpu
