Hello, today I received my new budget system/components.. i've put it all together, and it doesn't seem to boot up. The fan is spinning very slowly, and the monitor has no signal. I'm completely confused on what to do since i'm sure I set everything up properly.. The only problem I can think of is that the RAM/CPU is incompatible with the motherboard. My specs are:
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
OCZ Platinum Revision 2 XTC 2GB (2x1GB) PC2-6400C4 Dual Channel Series
Gigabyte GA-M61PME-S2P nForce 430 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard
Any advice is appreciated, thanks.
Also, my PSU is 600W.
Update: Figured out the problem, now I just need to somehow make my ram run at 1.8v.. or try and 'up' my voltage to 2.1v which it doesn't seem to let me in the BIOS :S.
