Hi All
Not sure if this is the correct location, but the PC bought from here died last week and looking for suggestions
1 x OcUK GeForce Titan X 12 TB
1 x Acer Predator XB270HU 27" G-Sync Monitor
1 x Intel 5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Proces
1x Asus X99-A Intel X99 (Socket 2011) DDR4 ATX Motherboard
1 x Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Channel Kit -
1 x Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State
1 x EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply
1 x Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler
1 x BeQuiet Silent Base 800
Extras:
1x 256 GB samsung evo,
Seagate 8TB BarraCuda 5400RPM 256MB Cache Internal Hard Drive (ST8000DM004)
AIO GPU cooling loop from EVGA
built in 2015, recently tried to turn on the pc and the cpu, psu and gpu fans span for a few seconds and nothing happened.
removed all external cables and onto the desk where I could see 00 on the led motherboard area. Seems CMOS was the issue, so removed the CMOS battery replaced the jumpers to 2-3 for a few mins. Jumpers back to 1-2 and a new battery inserted.
Now I get a red PWRSW and RSTW green on, no movement of any fans.
Removed ram, gpu no effect. then removed and replaced the cables from the PSU, also no effect
Drives removed and replaced with one from another pc that failed to work.
Writing this on a passive linux box.
Anyone got any suggestions as to the likely cause of failure and how to fix.
Could be a dead motherboard, psu or cpu ?
replaced the power lead from a working one and no issues there
Took a quick look on motherboard pages and the X99 does not seem to be sold any more which means that if I got someone local to take a look, they are unlikely to be able to fix with the same,
Due to the position of the CPU cooling fan, the ram sticks are not in optimal location, but nothing that could be done at the time.
So are there any checks that I can do this end with a multimeter that is somewhere in the house and if as I suspect the pc is dead, can I re-use the ram at least ?
And would it simply be a case of a new motherboard, CPU plus thermal paste ?
Not into overclocking, but still into gaming
edit: would be interested in an M2 boot drive, but not sure if any way to get the licence details off the old drive other than plugging it into this pc ?
Extras:
