9 Mar 2007 at 17:19 #1 BoomAM BoomAM Soldato Joined 5 Jul 2003 Posts 16,206 Location Atlanta, USA Hi. For the life of me i cant get a dead pixel tester to display on anything but my right hand screen. Even if set my left one to the primary! Any ideas?
9 Mar 2007 at 17:25 #2 Ray.uk Ray.uk Associate Joined 25 Dec 2002 Posts 401 Location Manchester Connect 1 monitor at a time to do the test
9 Mar 2007 at 17:27 #3 Ak!ta Ak!ta Associate Joined 10 Feb 2006 Posts 1,330 What program are you using for your dual monitors?
9 Mar 2007 at 23:50 #4 BoomAM BoomAM Soldato OP Joined 5 Jul 2003 Posts 16,206 Location Atlanta, USA Ak!ta said: What program are you using for your dual monitors? Click to expand... ? What program? As in, what am i testing with? Ray.uk said: Connect 1 monitor at a time to do the test Click to expand... Too much like hard work.
10 Mar 2007 at 11:45 #5 skanky skanky Associate Joined 21 Jul 2005 Posts 1,416 the amount of time you've waited for a solution, you could've connected the second monitor as a single monitor and tested by now
10 Mar 2007 at 12:01 #6 BoomAM BoomAM Soldato OP Joined 5 Jul 2003 Posts 16,206 Location Atlanta, USA skanky said: the amount of time you've waited for a solution, you could've connected the second monitor as a single monitor and tested by now Click to expand... lol. True. Thought of a lazy solution last nite: I just disabled the monitor i didnt want to test through CCC. lol. Thanks though everyone.
